Naming convention
    Other Naming convention
    Just thought I would let others know about naming your files. Follow the conventions that the forum has stated. (I have personally redone all mine 5 times).
    There are several problems that can cause database stuff ups.
    1) Movies can have several different names, always use name from scrapping database.
    2) Spelling mistakes
    3) Use full name EG Agatha Christie's Poirot (1989) not Poirot (1989)
    4) Make sure all spaces and brackets are there
    5) Make sure season and episode are done right
    Hope this will help others out, so that they will not have to go through the same head aches that I did.
    Viking lost down under
    1 other thing I found out of, is that if it has a long name (multiple words) and the capital letters are not all done as the data base used by DVDFab are using, you may not find what you are looking for. This happened once to me. I have a habit of only using capital letters for the first word that was why I couldn't find the movie; but as soon as I added the other capital letters it found it straight away. One that I could not find was " Harrow". It still does not show up, but if you type Arrow when editing metadata you will find it. Beats me.
