DVDFab10 and DVDFab9 folders
    Other DVDFab10 and DVDFab9 folders
    I have DVDFab 10.1.00 installed and found a DVDFab9 folder under This Computer > Documents, along with a DVDFab10 folder.
    The DVDFab9 folder subfolders:
    BDInfo
    Cinavia
    Log
    Temp
    Video
    The DVDFab10 folder subfolders:
    Log
    Temp
    I wonder why the DVDFab9 folder was kept after I uninstalled the 9 version long ago and also why these folders contents are different. Is the DVDFab9 folder needed for DVDFab 10 to work properly so I must keep it, or can I delete it?
    TIA.
    You can delete it, if it is needed a new folder will be created the next time you run DVDFab.
