File to Mobile Question
    I have been searching for a SIMPLE Manual for File to Mobile, I have a DVD I ran through DVDFAB to my HD, now I would like to put the FILE onto my IPhone, I select the File to Mobile Option, select all the Video Files, my target is correct, it starts the conversion for file 1 GREAT, then it all just stops, it will not continue to file 2,3,4,& 5.
    Appreciate the assistance.
    Dan
    Daniel Martin @
    SYSTEM INFO:
    Vista Home Basic
    Computer: Toshiba Satellite L305
    Processor: Intel Dual CPU T3400 @2.16Hz
    Memory: 2.00 GB
    System Type: 32-Bit Operating SYstem
    Hi Dan,
    This can get a bit confusing.
    If I'm understanding you correctly, you should be using DVD to Mobile.
    You ripped a dvd to your hdd and that's where you are now, right?
    Open DVD to Mobile and from the left pane select your device ----> iPod / iPhone >
    Select your Source and Target
    On the bottom of the Fab screen, select your profile ----> iPhone
    Finally, click Edit, and configure your settings.
    You can start with default and experiment a bit as you wish.
    See the attachments below:
      Forgot to mention...
      You should have a look at GregiBoy's sticky thread:
      Best Practice: DVD to Mobile
      I believe it will clear up any confusion and answer many of your questions
