Retaining Subtitles in Ripped Movies
    Other Retaining Subtitles in Ripped Movies
    Does anyone know how to keep subtitles and perhaps even some of the extras when you RIP instead of COPY a movie DVD? I know there are options on handbrake to do this, but where are the options with DVD Fab Ripper?
    with the source loaded in dvdfab, click the little wrench icon on the right hand side it'll say Advanced Settings
    when you hover over the wrench icon
      There are three modes for subtitle output in Ripper for most of the profiles, you can switch the modes to the one you need in Advanced Settings window.
      1> "Remux into file": you can disable or enable subtitle during playback;
      2> "Direct render to video": subtitles cannot be disable as they are embedded into the video (you can only choose one subtitle stream);
      3> "Extract to idx/sub file": you can disable or enable subtitle during playback, however some players don't support this kind of subtitle files.
