Dev Team using a TR4 or Intel 12+ Core CPU
    I would love to get this figured out on your software, DVDFab encoding engine utilizing more then 50% of the cpu.
    Don't ask me to attach my log files. All I want to see is anyone from the Dev Team using DVDFab and getting 90%+ on the encode engine using just the CPU, No GPU encoding.
    Hell I would settle for even 70-80%.
    Screenshot attached is my 16 core threadripper choking at 50%. And its overclocked as you can see to 4GHz all cores.
    That is set to only cpu encoding in the settings, no GPU. Hunter Killer (1080p bluray) self-ripped iso on a usb 3.1 SSD. Absolutely no bottlenecks. And it still only manages about 35fps encoding.
    If you think I'm being rude, sorry. I just think if your main business model is ripping/encoding. Then maybe you should optimize your engine to utilize most of your cpu.
    The attached pictures are too small. Please re-send, thanks. Also, we still want dvdfab_internal log and fabcheck_internal log, thanks.
