Help converting file
    Hi just wondering if anyone can help, I've ripped a blu ray disc to a MKV 4K H265 10Bit file approx 5-6gb in size
    Is there a way i can convert this file back to create a BDMV and CERTIFICATE folder and burn it onto a disc , playable as blu ray as opposed to a converted 4k file.
    if so which dvdfab programmes would i need?
    thanks
    Do you have the All In One DVDFab 11?
    In that package there is the Creator Modules. You could try the Blu-Ray Creator.
    I am not too sure if TS Muxer will accept your 10 Bit MKV file as a source to be able to export to a Blu-Ray folder/ISO.
      thanks Sieveis will try it, its accepted the file but explains Hevc codec is not standard for BD disks
        It appears to have worked but i'm left with a 5.5gb file to put onto a 25gb disc ;(
          Is there no way to change to a smaller size by clicking the small spanner icon (Advanced Settings)? That is for DVDFab.
          On occasions like this I would test burn on a re-writable Blu-Ray or a Dual Layer DVD. It has been know to work on the DL DVD on occasions especially if the output was set as an ISO file. I then use ImgBurn to burn the disc.
          Just a heads up, I'll be away from a computer today but if I can assist further I will get back to you.
            I used a blu ray Sieveis and it wasn't recognised on my oppo or ps4
              Sorry to hear that. Did you use TS Muxer or DVDFab creator?
                TS Muxer
