I don't want an NFO file for everything that I make but I can't find where to disable this option. Is the only way to disable the creation of NFO files to disable the use of metadata?
How to NOT generate an NFO file?
We will add the settings for create the nfo file in next version.
WilsonPlease post your logs the default location is:
