I'm using the latest HD Decrypter. Is there a way to disable auto eject when the copy is completed? I'd much rather the drive tray not pop out when the PC is unattended.
disable auto eject?
I do not use the free HD decryptor but in common settings-read towards the bottom put a check next to Do not eject source disc when finished copying. Now this part is if you have a paid version of DVDFab. Now in Write- towards bottom again put a check next to Do not eject disc when finished burning. That should fix you all up for the disc ejecting
