Auto Launch and Execute copy functions
    For the DVDFAB experts, Is there a way perform the following functions automatically in sequence:
    1 Launch DVDFAB upon insertion of disc. (I know this can be done)
    2 Read the disc and create folder names with predefined directory destination target.
    3 Execute copy function
    4 Close DVDFAB application when done.
    Thx
    Bnw
    Hello Bnw,
    If you are not talking about just input a movie disc to PC drive and then you don't need to move a finger, then you can use the command line to have a try:
    "C:\Program Files\DVDFab 11\DVDFab64.exe" /MODE "FULLDISC" /SRC "E:" /DEST "C:\Users\mona\Desktop\New folder" /OUTPUT "DVD9" /SLIENT /CLOSE
    Replace some of the information to yours.
    Here is more information about command line you may refer to:
    https://forum.dvdfab.cn/forum/dvdfab...d-sample-tasks
    DVDFab All-In-One is an all-inclusive solution package which can deal with all DVD/Blu-ray/4K UHD Blu-ray issues.
      Not too familiar with cmd editor, would I copy this to cmd prompt and need to run every time? Would like to auto launch every time a disc is loaded into the optical drive?
      Thx for the response Mona
