Uhd creator problem : Video pause and cannot run smoothly after conversion
    Hi, I had downloaded a MKV file and tried to convert the MKV to UHD Bluray format using UHD Creator and hoping to burn on a 50gb bluray disc and play on a 4k bluray player, after the conversion, the video cannot run smoothly, it pause and run slowly with sound but not in sync. The 2:35 video has become smaller size and picture is out of range {I mean the picture will not fit the screen). I have downloaded other MKV files uploaded by this uploader previously and all files had converted successfully but those files recently uploaded by this uploaded will have this problem. The original MKV file before conversion will have no problem playing on a 4k Bluray Player but the 4K Bluray cannot play Atmos audio on MKV file, it will only play on UHD BD structure files. I have updated the latest version of DVDFab but it won't help. By the way, I have to download UHD MKV from website because my country does not sell any UHD BLURAY DISC movies because all video shops have closed down nowadays because most peoples prefer to watch movies online like Netflix or Astro . I hope DVDfab can fix this problem for me, failing which I have wasted my money to buy this expensive software and doing nothing for me. I support original but I have no choice. If I import UHD DISC from overseas, the cost is very very expensive.
    Below is the media info of the MKV file, I shall be much obliged if DVDFab can correct this problem. Thank you.
    Video
    ID in the original source medium : 4113 (0x1011)
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    HDR format : SMPTE ST 2086, HDR10 compatible
    Codec ID : V_MPEGH/ISO/HEVC
    Duration : 1 h 37 min
    Bit rate : 51.0 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.257
    Stream size : 34.8 GiB (77%)
    Title : Resident.Evil.Apocalypse.2004.EXTENDED.2160p.BluRa y.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
    Language : English
    Default : No
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : Display P3
    Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
    Maximum Content Light Level : 992 cd/m2
    Maximum Frame-Average Light Level : 781 cd/m2
    Original source medium : Blu-ray
    Audio #1
    ID in the original source medium : 4352 (0x1100)
    Format : MLP FBA 16-ch
    Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
    Commercial name : Dolby TrueHD with Dolby Atmos
    Codec ID : A_TRUEHD
    Bit rate mode : Variable
    Bit rate : 3 467 kb/s
    Maximum bit rate : 6 033 kb/s
    Channel(s) : 8 channels
    Channel layout : L R C LFE Ls Rs Lb Rb
    Sampling rate : 48.0 kHz
    Frame rate : 1 200.000 FPS (40 SPF)
    Compression mode : Lossless
    Stream size : 2.37 GiB (5%)
    Language : English
    Default : Yes
    Forced : No
    Number of dynamic objects : 11
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Audio #2
    Format : DTS XLL
    Format/Info : Digital Theater Systems
    Commercial name : DTS-HD Master Audio
    Codec ID : A_DTS
    Bit rate : 4 478 kb/s
    Channel layout : C L R LFE Lb Rb Lss Rss
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Stream size : 3.06 GiB (7%)
    Default : No
    Forced : No
    Audio #3
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 640 kb/s
    Channel(s) : 6 channels
    Frame rate : 31.250 FPS (1536 SPF)
    Compression mode : Lossy
    Stream size : 448 MiB (1%)
    Language : English
    Service kind : Complete Main
    Default : No
    Forced : No
    Audio #4
    ID in the original source medium : 4354 (0x1102)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Stream size : 134 MiB (0%)
    Language : English
    Default : No
    Forced : No
    Audio #5
    ID in the original source medium : 4355 (0x1103)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : French
    Default : No
    Forced : No
    Audio #6
    ID in the original source medium : 4356 (0x1104)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : French
    Default : No
    Forced : No
    Audio #7
    ID in the original source medium : 4357 (0x1105)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Hindi
    Default : No
    Forced : No
    Audio #8
    ID in the original source medium : 4358 (0x1106)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Italian
    Default : No
    Forced : No
    Audio #9
    ID in the original source medium : 4359 (0x1107)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Japanese
    Default : No
    Forced : No
    Audio #10
    ID in the original source medium : 4360 (0x1108)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Polish
    Default : No
    Forced : No
    Audio #11
    ID in the original source medium : 4361 (0x1109)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Portuguese
    Default : No
    Forced : No
    Audio #12
    ID in the original source medium : 4362 (0x110A)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Spanish
    Default : No
    Forced : No
    Audio #13
    ID in the original source medium : 4363 (0x110B)
    Format : AC-3
    Codec ID : A_AC3
    Bit rate : 640 kb/s
    Language : Spanish
    Default : No
    Forced : No
    Text #1
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Duration : 1 h 31 min
    Bit rate : 31 b/s
    Count of elements : 716
    Stream size : 21.1 KiB (0%)
    Title : English-SRT
    Language : English
    Default : Yes
    Forced : No
    Text #2
    ID in the original source medium : 4768 (0x12A0)
    Format : PGS
    Muxing mode : zlib
    Codec ID : S_HDMV/PGS
    Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
    Duration : 1 h 36 min
    Bit rate : 22.3 kb/s
    Count of elements : 1869
    Stream size : 15.4 MiB (0%)
    Title : English-SDhHPGS
    Language : English
    Default : No
    Forced : No
    Text #3
    ID in the original source medium : 4769 (0x12A1)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 18.6 kb/s
    Count of elements : 1432
    Stream size : 12.2 MiB (0%)
    Title : English-PGS
    Language : English
    Default : No
    Forced : No
    Text #4
    ID in the original source medium : 4772 (0x12A4)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 10.7 kb/s
    Count of elements : 1556
    Stream size : 7.41 MiB (0%)
    Title : Arabic-PGS
    Language : Arabic
    Default : No
    Forced : No
    Text #5
    ID in the original source medium : 4773 (0x12A5)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 17.4 kb/s
    Count of elements : 1564
    Stream size : 11.4 MiB (0%)
    Title : Chinese-PGS
    Language : Chinese
    Default : No
    Forced : No
    Text #6
    ID in the original source medium : 4774 (0x12A6)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 16.3 kb/s
    Count of elements : 1568
    Stream size : 11.3 MiB (0%)
    Title : Chinese-PGS
    Language : Chinese
    Default : No
    Forced : No
    Text #7
    ID in the original source medium : 4775 (0x12A7)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 15.2 kb/s
    Count of elements : 1262
    Stream size : 10.6 MiB (0%)
    Title : Danish-PGS
    Language : Danish
    Default : No
    Forced : No
    Text #8
    ID in the original source medium : 4776 (0x12A8)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 18.0 kb/s
    Count of elements : 1498
    Stream size : 12.5 MiB (0%)
    Title : Dutch-PGS
    Language : Dutch
    Default : No
    Forced : No
    Text #9
    ID in the original source medium : 4777 (0x12A9)
    Format : PGS
    Muxing mode : zlib
    Count of elements : 1340
    Stream size : 10.7 MiB (0%)
    Title : Finnish-PGS
    Language : Finnish
    Default : No
    Forced : No
    Text #10
    ID in the original source medium : 4778 (0x12AA)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 19.8 kb/s
    Count of elements : 1590
    Stream size : 13.7 MiB (0%)
    Title : French-PGS
    Language : French
    Default : No
    Forced : No
    Text #11
    Format : PGS
    Muxing mode : zlib
    Duration : 1 h 34 min
    Bit rate : 2 448 b/s
    Count of elements : 206
    Stream size : 1.66 MiB (0%)
    Title : French-FORCED-PGS
    Language : French
    Default : No
    Forced : No
    Text #12
    ID in the original source medium : 4779 (0x12AB)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 20.2 kb/s
    Count of elements : 1435
    Stream size : 13.3 MiB (0%)
    Title : Greek-PGS
    Language : Greek
    Default : No
    Forced : No
    Text #13
    ID in the original source medium : 4780 (0x12AC)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 14.9 kb/s
    Count of elements : 1560
    Stream size : 9.82 MiB (0%)
    Title : Hindi-PGS
    Language : Hindi
    Default : No
    Forced : No
    Text #14
    Format : PGS
    Muxing mode : zlib
    Duration : 1 h 21 min
    Bit rate : 2 870 b/s
    Count of elements : 284
    Stream size : 1.67 MiB (0%)
    Title : Hindi-FORCED-PGS
    Language : Hindi
    Default : No
    Forced : No
    Text #15
    ID in the original source medium : 4781 (0x12AD)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 19.6 kb/s
    Count of elements : 1430
    Stream size : 13.6 MiB (0%)
    Title : Indonesian-PGS
    Language : Indonesian
    Default : No
    Forced : No
    Text #16
    ID in the original source medium : 4782 (0x12AE)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 20.4 kb/s
    Count of elements : 1562
    Stream size : 13.4 MiB (0%)
    Title : Italian-PGS
    Language : Italian
    Default : No
    Forced : No
    Text #17
    Format : PGS
    Muxing mode : zlib
    Bit rate : 4 117 b/s
    Count of elements : 274
    Stream size : 2.40 MiB (0%)
    Title : Italian-FORCED-PGS
    Language : Italian
    Default : No
    Forced : No
    Text #18
    ID in the original source medium : 4783 (0x12AF)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 13.2 kb/s
    Count of elements : 1531
    Stream size : 8.71 MiB (0%)
    Title : Japanese-PGS
    Language : Japanese
    Default : No
    Forced : No
    Text #19
    ID in the original source medium : 4784 (0x12B0)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 14.6 kb/s
    Stream size : 10.1 MiB (0%)
    Title : Korean-PGS
    Language : Korean
    Default : No
    Forced : No
    Text #20
    ID in the original source medium : 4785 (0x12B1)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 17.1 kb/s
    Count of elements : 1396
    Stream size : 11.2 MiB (0%)
    Title : Norwegian-PGS
    Language : Norwegian
    Default : No
    Forced : No
    Text #21
    ID in the original source medium : 4786 (0x12B2)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 17.9 kb/s
    Count of elements : 1554
    Stream size : 12.4 MiB (0%)
    Title : Polish-PGS
    Language : Polish
    Default : No
    Forced : No
    Text #22
    Format : PGS
    Muxing mode : zlib
    Duration : 1 h 33 min
    Bit rate : 1 996 b/s
    Count of elements : 174
    Stream size : 1.33 MiB (0%)
    Title : Polish-FORCED-PGS
    Language : Polish
    Default : No
    Forced : No
    Text #23
    ID in the original source medium : 4787 (0x12B3)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 17.8 kb/s
    Count of elements : 1548
    Title : Portuguese-PGS
    Default : No
    Forced : No
    Text #24
    Format : PGS
    Muxing mode : zlib
    Bit rate : 2 107 b/s
    Count of elements : 176
    Stream size : 1.41 MiB (0%)
    Title : Portuguese-FORCED-PGS
    Default : No
    Forced : No
    Text #25
    ID in the original source medium : 4788 (0x12B4)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 19.4 kb/s
    Count of elements : 1566
    Default : No
    Forced : No
    Text #26
    Format : PGS
    Muxing mode : zlib
    Bit rate : 1 839 b/s
    Count of elements : 128
    Stream size : 1.25 MiB (0%)
    Default : No
    Forced : No
    Text #27
    ID in the original source medium : 4789 (0x12B5)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 19.0 kb/s
    Stream size : 13.2 MiB (0%)
    Title : Russian-PGS
    Language : Russian
    Default : No
    Forced : No
    Text #28
    ID in the original source medium : 4790 (0x12B6)
    Format : PGS
    Muxing mode : zlib
    Title : Spanish-PGS
    Language : Spanish
    Default : No
    Forced : No
    Text #29
    Format : PGS
    Muxing mode : zlib
    Duration : 1 h 35 min
    Bit rate : 3 765 b/s
    Count of elements : 300
    Stream size : 2.58 MiB (0%)
    Title : Spanish-FORCED-PGS
    Language : Spanish
    Default : No
    Forced : No
    Text #30
    ID in the original source medium : 4791 (0x12B7)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 20.0 kb/s
    Title : Spanish-PGS
    Language : Spanish
    Default : No
    Forced : No
    Text #31
    Format : PGS
    Muxing mode : zlib
    Duration : 1 h 19 min
    Bit rate : 2 804 b/s
    Count of elements : 198
    Stream size : 1.60 MiB (0%)
    Language : Spanish
    Default : No
    Forced : No
    Text #32
    ID in the original source medium : 4792 (0x12B8)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 15.6 kb/s
    Count of elements : 1172
    Stream size : 10.8 MiB (0%)
    Title : Swedish-PGS
    Language : Swedish
    Default : No
    Forced : No
    Text #33
    ID in the original source medium : 4793 (0x12B9)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 20.5 kb/s
    Stream size : 14.2 MiB (0%)
    Title : Thai-PGS
    Language : Thai
    Default : No
    Forced : No
    Text #34
    ID in the original source medium : 4794 (0x12BA)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 2 389 b/s
    Count of elements : 180
    Stream size : 1.39 MiB (0%)
    Language : French
    Default : No
    Forced : No
    Text #35
    Format : PGS
    Muxing mode : zlib
    Bit rate : 2 388 b/s
    Count of elements : 172
    Language : French
    Default : No
    Forced : No
    Text #36
    ID in the original source medium : 4795 (0x12BB)
    Format : PGS
    Muxing mode : zlib
    Bit rate : 1 049 b/s
    Count of elements : 94
    Stream size : 626 KiB (0%)
    Title : Japanese-FORCED-PGS
    Language : Japanese
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:Chapter 01
    00:05:56.064 : en:Chapter 02
    00:14:52.057 : en:Chapter 03
    00:19:37.843 : en:Chapter 04
    00:25:21.353 : en:Chapter 05
    00:32:20.355 : en:Chapter 06
    00:39:09.972 : en:Chapter 07
    00:46:07.139 : en:Chapter 08
    00:52:21.388 : en:Chapter 09
    01:00:25.663 : en:Chapter 10
    01:04:40.126 : en:Chapter 11
    01:11:07.680 : en:Chapter 12
    01:17:11.877 : en:Chapter 13
    01:22:06.087 : en:Chapter 14
    01:26:25.763 : en:Chapter 15
    01:28:27.010 : en:Chapter 16
    Can this problem be fixed, any response ?
      Finally I got my problem settled, I am using Acer XC780 HD630 graphic to decode the video, the genius windows 10 automatically updated my graphic card to the latest version causing this problem. I have to use older graphic version to decode X265 video, very weird for a software like DVDfab ! .
