DVDFab x64 12.0.3.5 use HEVC
    Hi, I've just purchased the DVDFab 12 bundle and am trying to get to grips with the various features. I've successfully ripped a DVD to MKV using h264 in Ripper and converted the output to HEVC in Converter. However, HEVC is my default format of choice and I would like to be able to rip directly to this format. I've found guides to adding parameters but none for enabling the codec in Ripper. I'm using Win 10 and can play back HEVC material with no problems using VLC or Kodi. I'm sure there must be a way to set up an HEVC profile but I'm drowing in a sea of options and can't find it.
    Never mind, I found it, For any other novices, you can get there via Other Profiles. Easy when you know how
