from Netflix to copy using DVDfab
    HELP After downloading a movie from Netflix how can I download it to a disc using DVDfab? thanks
    You can use DVD Creator or Blu-ray Creator to convert the downloaded movie into DVD/Blu-ray format and then burn to blank media.
    DVD Creator and Blu-ray Creator are in DVDFab 12, you can download it at https://www.dvdfab.cn/download.htm
      thanks for that.All go ☺
        Something else is bothering me ☺ On Netflix I did put 4 movies into the Task Queue ready for download.BUT when I click on Download it only starts with the first one on top of the list. I tried to play numbers 2,3, or 4 first but this does not work. It only starts with the one on top of the list. Any suggestion to make this better? Thanks, BERT
