Merging... how to do this using multiple discs
    Other Merging... how to do this using multiple discs
    If I, say, wanted to create a disc comprised of nothing but trailers, sourced fromtwenty or thirty different discs, how do I go about it? Do they all have to be saved in a Fab folder on my hard drive first? How is this done (I haven't enough hard drive space to save the full content of all of them just to retrieve the trailers, for example). The merging process confuses me. Thanks!
    Am I understanding you to say that you don't have adequate storage for 20-30 trailers?...then I wouldn't try
    I wouldn't try to merge them with Fab either.
    Once I have them ripped, I would use re-authoring software ...something like good old reliable shrink.
    Boy o' boy, you must be one patient dude
