BluRay Main Copy convert DTS to AC3 always failing
    Since a couple of weeks I am unable to convert any BluRay with a DTS track to AC3 using Main Movie, process is always failing.
    Tool used to work perfectly a few weeks back.
    Any help please ?
    Regard’s
    /SOURCE BLURAY/Last.Man.Down.2021.1080p.BluRay.AVC.DTS-HD.MA.5.1-FGT
    Is it a downloaded copy? Do you have the original movie disc to have a try?
      It's downloaded copy (full movie in BD format), it's been working from the same format for a while, I will try from an original physical media and let you know
        Hello Mona, I tried with an original physical disc, Main Movie to BD folder (Convert DTS to AC3) did not complete the BD structure, disc copy won't even be playable, and I tried MainMovie to ISO (Convert DTS to AC3) did not even write a file...
        Logs attached
        thank you
