DVD Creator, disc menu MB
    Performance DVD Creator, disc menu MB
    I have noticed in "dvd creator mode" that whatever I choose "no menu" or "with menu" It doesn't change the writable media space. It would be great if we can gain some MB disc space when we choose "no menu". Some times I use dvd5 disc when the movie isn't long but even if they are 4.7G of space, I can only use 4.4G and I presume it's because of the "menu sector" that is already programmed in the available disc space. If you guy can fix that issue, it would be great
    You can adjust the output size in the Common Settings window.
    However, 4300MB is considered a safe size for burning to DVD5 disc.
    The menu part should not take up much size.
