StreamFab - Should I use VPN?
    Other StreamFab - Should I use VPN?
    Hi!
    Does anyone use a VPN when you download movies on StreamFab? I know Disney always traces the IP of the downloader and reports them to their ISP. Should I be worried about this and use VPN whenever I use StreamFab? Thoughts? Thanks.
    I use VPN with the same local US server at Peacock and have done so for about a year on my Shield TV Pro, there no issues.
    Recently i got StreamFab which i also use at Peacock and there i use the very same local server as on my Shield TV Pro.
    This is basically to avoid raising the suspicion that i use a VPN server, because then they see that i always are loging in using the exact same server.
    So far so good, i yet have to recieve a complaint mail on the Gmail adress i used to register with.
    I guess thats the trick to use, same local server all the time, because jumping around from one server to another all the time could raise suspicion.
      Completely make sense. I will make sure I will use the same local server. Thanks
