Regions and Formats
    Other Regions and Formats
    My first post, forgive me if the wrong forum. Did not find my questions in searching the previous threads. Have had DVD FAB for few years with upgrades along along the way. Know some things about DVDs and computers, woefully ignorant about much of the topic.
    DVDFab6 asks for the Region Code of the disc. (1) What if I don't know the code? (2) What if the Code is zero? (3) What if I enter a Code different from the actual? (4) Different sources say that DVDFab will convert PAL to NTSC, but I find no way to do that. My efforts merely copy the PAL disc into a PAL clone. How to create NTSC from PAL?
    Additional questions later.
    Thank you for any help offered.
    DVDFab does not convert from PAL to NTSC or from NTSC to PAL. You need to use another program for that. As for the region code that back of the DVD case should tell you what the region is that the DVD came from. If you are only doing the DVDs from your home country then enter that region code. You can also change DVDFab to use that region and to never ask the region again.
