A cousin in England sent us a DVD which is Region 2. We're in Region 4 at the moment, with satellite beamed from Region 1. Any way that DVD Fab can make it region free (unlock codes) so we can play it?
as long as DVDFab is set to remove a region protections and copy protections and you TV/DVD player can play the video format the DVD is in then Yes DVDFab can do that. Make sure your set up can play NTSC or PAL format and check to make sure the DVD is the format that can be played
