DVDFab 13 for Windows x86 or 32-bit
    I'm not certain the forum section to post this question.
    Move it if it needs to be in a different section.
    There is now only a x64 available for DVDFab 13.
    I have the last version of DVDFab 12 version 12.1.1.5 7/09/2003 installed & activated on my x86 computer.
    So when will a x86 version be out ?
    This is the computer I use for ripping optical discs.
    I let it work on things like this so it does not use resources on my main computer which is also x86.
    I do have two x64 computers but I do not plan to install & activate DVDFab on those.
    One is a HTPC & the other a laptop.
    I have used DVDFab since the free DVDFab HD Decrypter.
    I purchased DVDFab Platinum 5 lifetime in 2008.
    Back then I could use it offline & no "Activation" check was done or required.
    The only time I needed online was to update.
    Since DVDFab only allows activation on one computer at a time unless a multiple computer license is purchased.
    I do not need a multiple computer license & I do not want to use up my single computer activations by switching back & forth. Since the number of times for doing this is limited.
    So I need a x86 version of DVDFab 13 .​or
    continued updates for DVDFab 12
    I was hoping the DVDFab staff would have an answer to if a 32 bit version is going to be available at some time.
