download
    download
    I tried to download the newest version of Beta 7.0.2.7 but it would not download because it said the file was corrupted. I need to know if there is anyone that can help me with this problem? Thanks
    After seeing your thread I did a test download and yes there does seem to be a problem.
    Nothing anyone on the forum can do.
    The crew in China will have to check it out.
    You might try again in an hour.
      bboochie
      I always do this for all my programs, instead of clicking run I click save then open the folder and right click and install the programs as administrator and never have had 1 problem with any install. In my own opinion I think it makes a world of difference on the install of programs.
      Give it a try and post back.
