If i download and install the HD Decrypter from , the complete DVDFab is installed with all Options available and all set to "Trial User" (HD Decrypter to "Free Edition").
All i want to do is to copy the main movie from a copy protected DVD to my HD without any compression (maybe just not with all available languages and subtitles).
So i check "DVD to DVD -> Main Movie", set the target directory (and some other options) and start the process. During the process the status window says "You are going to try "DVD to DVD" Option" although i am ripping to my hard-drive.
Am i in fact already using the free HD Decrypter?
Do i have to purchase the product after the Update Expire Time?
How can i access the free HD Decrypter?
What are the restrictions of the HD Decrypter after the Update Expire Time of "DVD to DVD"?
I searched the forum but i found no satisfying answer to the questions above. There is nowhere a clear explanation about how to specifically use only the free HD Decrypter feature without the need of buying anything.
It would be clearer for me if there was an additional frame on the left side of the main window called "HD Decrypter". All other options (currently marked as "Trial User") are there, why not the HD Decrypter?
Edit:
Sorry, i missed the other HD Decrypter thread...
Is it true that the HD Decrypter is in fact the full version? You just can't do any compression and target is hdd only?
Edit:
