Is there any way to rip 1440p movies with 4K UHDs with UHD Ripper?
    I have a LG WH16NS60 with firmware 1.0. Running version 13 of DVDFab. I'm able to rip 4K movies with no problems. I'm pretty sure with earlier versions of DVDFab it would allow you to rip at a variety of resolutions. With DVDFab UHD Ripper it appears that it only allows 1080p or 4K movies. I have a 1440p monitor and also files sizes would be a bit more manageable at 1440p and would still look great on 4K TVs. Are earlier versions of DVDFab capable of ripping 1440p/2K movies from UHDs? Thanks for any help.
    You may manually set the resolution in the Advanced Settings panel.
      Thank you. When I click on wrench it only allows me to select 3840x2160. Do I have to select another profile to select 2560x1440?
        Hi there, in the picture above under resolution, where it shows 3840x2160, manually type in 2560x1440.
          Thanks for the tip!
