Hello,
I have just seen that very few audio formats seem compatible with DVDFAB Blu-ray After Editor. When adding sounds, I realized that when reading, the following sounds could be added, that the operation was successfully finalized but that when reading with several different readers, the Audios DTS, E-AC3, True HD, Dolby Atmos or AC3 formats with a bitrate of more than 640 kbps are silent.
And It is not my amps or my readers who are in question : in effect these sounds pass very well when they are listened to from the sources from which they were extracted.
I tried to add them in one go and then in several times, it doesn't change anything.
It is a big disappointment that makes me regret having bought a life license. Unless there is a reason that escapes me. I hope there will be urgent updates that will be set up to remedy this heavy weak point of the software.
Already that the Blu-Ray 3D format is not supported, it is starting to do a lot !
Yours.
Didier Sterroz
Yours.
Didier Sterroz
