Uhd creator resolution problem
    Hi, I am using UHD Creator to create BDMV folder from MKV, just recently i have noticed that the output resolution of mt2s file is 3840 X 2176p and not 3840X2160p according to the UHD format. But prior to that the output resolution was 3840 x 2160p. How to fix this? All MKV files infected with this problem. I want to use TSMUXER to add subtitles to the mt2s file but TSMUXER reject those files because it is not UHD format standard. Please help. I am using NVIDIA GTX 1060 6GB display card. Please help. Thank you.
