Lastest DVDFab version and imgburn????
    Other Lastest DVDFab version and imgburn????
    So I'm a NewBe...My son has special needs so I try to backup his DVDs and CDs so he doesn't destroy them by leaving the lay out everywhere. I have attached a log from my latest try...I installed the latest version of DVDFab 7.0.4.0 and Imgburn 2.4.4.0...Set imgburn write settings to that what I have found here on the forum....and since I have thrown out 5 disc (3 DVD-5 and 2 DVD-9) because they fail to write...Any Help!!!
    I 17:07:34 ImgBurn Version 2.4.4.0 started!
    I 17:07:34 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
    I 17:07:34 Total Physical Memory: 1,047,276 KB - Available: 655,976 KB
    I 17:07:34 Initialising SPTI...
    I 17:07:34 Searching for SCSI / ATAPI devices...
    I 17:07:34 Found 2 DVD±RWs!
    I 17:07:34 Operation Started!
    I 17:07:34 Building Image Tree...
    I 17:07:35 Checking Directory Depth...
    I 17:07:35 Calculating Totals...
    I 17:07:35 Preparing Image...
    I 17:07:35 Checking Path Length...
    I 17:07:35 Contents: 13 Files, 2 Folders
    I 17:07:35 Content Type: DVD Video
    I 17:07:35 File System(s): ISO9660, UDF (1.02)
    I 17:07:35 Volume Label: BLIND_SIDE
    I 17:07:35 IFO/BUP 32K Padding: Enabled
    I 17:07:35 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
    I 17:07:35 TV System: NTSC
    I 17:07:35 Size: 4,497,244,160 bytes
    I 17:07:35 Sectors: 2,195,920
    I 17:07:35 Image Size: 4,497,899,520 bytes
    I 17:07:35 Image Sectors: 2,196,240
    I 17:07:35 Operation Successfully Completed! - Duration: 00:00:00
    I 17:07:35 Operation Started!
    I 17:07:35 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 17:07:35 Source File Sectors: 2,196,240 (MODE1/2048)
    I 17:07:35 Source File Size: 4,497,899,520 bytes
    I 17:07:35 Source File Volume Identifier: BLIND_SIDE
    I 17:07:35 Source File Application Identifier: IMGBURN V2.4.4.0 - THE ULTIMATE IMAGE BURNER!
    I 17:07:35 Source File Implementation Identifier: ImgBurn
    I 17:07:35 Source File File System(s): ISO9660, UDF (1.02)
    I 17:07:35 Destination Device: [3:0:0] LITE-ON DVDRW SOHW-1693S KS0B (E (ATA)
    I 17:07:35 Destination Media Type: DVD-R (Disc ID: CMC MAG. AM3) (Speeds: 6x, 8x, 12x, 16x)
    I 17:07:35 Destination Media Sectors: 2,297,888
    I 17:07:35 Write Mode: DVD
    I 17:07:35 Write Type: DAO
    I 17:07:35 Write Speed: 12x
    I 17:07:35 Link Size: Auto
    I 17:07:35 Lock Volume: Yes
    I 17:07:35 Test Mode: No
    I 17:07:35 OPC: No
    I 17:07:35 BURN-Proof: Enabled
    W 17:07:40 DeviceIoControl(FSCTL_LOCK_VOLUME) Failed! - Reason: Access is denied.
    W 17:07:40 DeviceIoControl(FSCTL_DISMOUNT_VOLUME) Failed! - Reason: Access is denied.
    I 17:07:40 Advanced Settings - Force HT: N/A, Online HT: N/A, OverSpeed: N/A, SmartBurn: No
    I 17:07:42 Filling Buffer... (40 MB)
    I 17:07:46 Writing LeadIn...
    I 17:09:21 Writing Session 1 of 1... (1 Track, LBA: 0 - 2196239)
    I 17:09:21 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2196239)
    W 17:10:05 Failed to Write Sectors 1472 - 1503 - Reason: No Additional Sense Information
    W 17:10:05 Retrying (1 of 20)...
    W 17:10:06 Retry Failed - Reason: Command Sequence Error
    W 17:10:06 Retrying (2 of 20)...
    W 17:10:06 Retrying (3 of 20)...
    W 17:10:06 Retrying (4 of 20)...
    W 17:10:06 Retrying (5 of 20)...
    W 17:10:06 Retrying (6 of 20)...
    W 17:10:06 Retrying (7 of 20)...
    W 17:10:06 Retrying (8 of 20)...
    W 17:10:06 Retrying (9 of 20)...
    W 17:10:06 Retrying (10 of 20)...
    W 17:10:06 Retrying (11 of 20)...
    W 17:10:06 Retrying (12 of 20)...
    W 17:10:06 Retrying (13 of 20)...
    W 17:10:06 Retrying (14 of 20)...
    W 17:10:06 Retrying (15 of 20)...
    W 17:10:06 Retrying (16 of 20)...
    W 17:10:06 Retrying (17 of 20)...
    W 17:10:06 Retrying (18 of 20)...
    W 17:10:06 Retrying (19 of 20)...
    W 17:10:06 Retrying (20 of 20)...
    E 17:10:18 Failed to Write Sectors 1472 - 1503 - Reason: No Additional Sense Information
    I 17:10:18 Synchronising Cache...
    W 17:10:21 User opted to skip the 'Close Track/Session/Disc' functions.
    E 17:10:21 Failed to Write Image!
    I 17:10:24 Exporting Graph Data...
    I 17:10:24 Graph Data File: C:\Documents and Settings\Owner\Application Data\ImgBurn\Graph Data Files\LITE-ON_DVDRW_SOHW-1693S_KS0B_SUNDAY-APRIL-18-2010_5-07_PM_CMC_MAG._AM3_12x.ibg
    I 17:10:24 Export Successfully Completed!
    E 17:10:24 Operation Failed! - Duration: 00:02:45
    I 17:10:24 Average Write Rate: 52 KB/s (0.0x) - Maximum Write Rate: 52 KB/s (0.0x)
    I 17:10:26 Close Request Acknowledged
    I 17:10:26 Closing Down...
    I 17:10:26 Shutting down SPTI...
    I 17:10:26 ImgBurn closed!
    It looks like that some other software that you have installed is controlling your burner and not allowing access.
    What other DVD software do you have installed?
      Also download the latest release of imgburn v2510
        DVDFAB locks the drive and will not let imgburn access it.
        Need to disable one of them from locking the drive.
          Use ImgBurn under ImgBurn settings and post the filter drive load order as it sounds like might have a bad filter installed that is not allowing access to the DVD drive
            The discs you are using are prone to not to write, they are of low quality
            CMC MAG. AM3 I would change the burn speed to 8X.
              Ok.... I have uninstalled DVD Decrypter and tried DVDFab again and it burned the DVD I had on the Hard drive
                FYI..The last batch of VERBATIM I purchased a couple weeks ago have an mid of CMC MAG AM3.
                Yes they have proven to be sub standard quality regardless of the well known and recommended name.
