Good evening everyone, not sure what I did wrong or am missing but was backing up Avatar, full disk DVD-9, burned with imgburn and will play on LG standalone player but will not on Samsung player, (both upconverts to 1080i). So I tried with VSO engine and it played ok on both. Am I missing a setting in imgburn? Also, not sure if this should go in general question or in third party products? ( mod can move if they need to no worries) I am using paid version of 7040.
Imgburn 2510 and Avatar?
Guest
Chris do you have a burn log from imgburn you can post?
I had this happen a year or so ago in regards to a samsung player not working but 2 LG players had no problem.
At the moment I can not remember what I did to correct this.. Hoping the burn log will jog my memory.
Guest
Open imgburn and click on Help then scroll down to the logs listing and click on it.
Copy / paste what ever you find.
Yup, the logs hopefully will tell the tale.
Any chance that it didn't bitset with Img?
Did you alter the playback order on any of the titles?If it ain't broke, don't fix it!
I found the note pad, but this is all it had for today??? There is an older one from Sherlock Homes, but this one worked with the samsung player.
; ImgBurn Version 2.5.1.0 - Log
; Thursday, 22 April 2010, 15:37:55
I 15:36:34 ImgBurn Version 2.5.1.0 started!
I 15:36:34 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 15:36:34 Total Physical Memory: 2,030,956 KB - Available: 1,275,712 KB
I 15:36:34 Initialising SPTI...
I 15:36:34 Searching for SCSI / ATAPI devices...
I 15:36:34 -> Drive 1 - Info: LITE-ON DVDRW LH-18A1P GL0B (D(ATA)
I 15:36:34 Found 1 DVD±RW/RAM!
I 15:37:55 Close Request Acknowledged
I 15:37:55 Closing Down...
I 15:37:55 Shutting down SPTI...
I 15:37:55 ImgBurn closed!Chris
Originally posted by maineman View PostYup, the logs hopefully will tell the tale.
Did you alter the playback order on any of the titles?Chris
Guest
Chris
Do you have ImgBurn set up as Troy's tutorial? If so go to C:\Documents and Settings\User Name\My Documents\DVDFab\Log.and post the DVDFab_burn_imgburn log files.
I don't if this helps but your drive has a firmware update you will find it here
CBR929Last edited by CBR929; 04-23-2010, 01:30 AM.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by chris View Postburned with imgburn and will play on LG standalone player but will not on Samsung player, (both upconverts to 1080i). So I tried with VSO engine and it played ok on both. Am I missing a setting in imgburn?
Just thought I would pass this on, hope it helps.
rip
Originally posted by ripvanwinkle1819 View PostHi Chris I have copied Avatar with DVD Fab 7.0.4.0 DVD 9 and also use an upconverting Toshiba. I had a similar issue before, when I first bought this unit. I found that on the window that comes up to choose the layer break position, I had to un click seamless. If you go into the IMGBURN settings, you can find the seamless selection and do this permanently.
rip
I was just looking over this thread and the thought struck me...what about the seamless layer break...and there was your post...
Too bad Chris can't find the VSO and Img burn logs on Avatar to compare.
@chris
In addition to rip's idea (hopefully that does it), please check and see if your Img burn was bitset, ie.,
booktype changed from +R to DVD-ROM.
+R media (+R, +R DL, +RW) can be a problem for many standalone players and just won't play unless bitset to DVD-ROM
Nero cd-dvd speed, VSO Inspector, Img, etc., will display this info.
Here's a link for VSO Inspector:
http://www.vso-software.fr/products/inspector/inspector.php
Here's a screenshot:
@ maineman, think I found what you were looking for, I tried again with imgburn and will play on lg but not samsung. will attach the logs. Also, where do I find the book type in imgburn? I unchecked seamless layer break as rip sugested. BTW, don't waste the time to type CRAPPY media, I know these are not good but only have a couple left and then to the good stuff!
******************** Log session stop 22-Apr 16:48:42.750 PID 1508********************
2010-04-22 16:46:55 Info Disc ejected by user while parsing.
2010-04-22 16:46:51 Info Parsing disc ...
2010-04-22 16:44:43 Info WRITE SUCCESS: Disc written
2010-04-22 16:44:43 Info Finalization Time 00:00:45 - Total completion time 00:17:08
2010-04-22 16:43:57 Info Write finished in 00:16:22 - Finalization start here. Avg. burn rate 6.62
2010-04-22 16:27:37 Info Lead-in burning time (mS) 2160
2010-04-22 16:27:34 Info Write started 4002304 sectors to write
2010-04-22 16:27:34 Info Init success: DVD+R Dual Layer
2010-04-22 16:27:34 Info Init DVD+R Dual Layer: Layer change set to LBA 2001168 (3.82 Gb.)
2010-04-22 16:26:25 Info Writing speed requested x8.0, effective x8.0
2010-04-22 16:26:25 Info layer break set by filesystem builder at 0
2010-04-22 16:26:25 Info Available write speed: 8x ,6x ,4x ,2.4x
2010-04-22 16:26:25 Info Media ID: RITEK-S04-42
2010-04-22 16:26:25 Info Media type: Dual Layer DVD+R
2010-04-22 16:26:25 Info DMA Mode
2010-04-22 16:26:25 Info Scanned files #29, folder #2 - total size 8195579904 b. (7.63 Gb.)
2010-04-22 16:26:25 Info Inserted media type : DL DVD+R
2010-04-22 16:26:25 Info Write started
2010-04-22 16:26:23 Info Writable disc DL DVD+R inserted. Ready to write
2010-04-22 16:26:03 Info Parsing disc ...
2010-04-22 16:25:57 Info No disc in drive.
2010-04-22 16:25:55 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-04-22 16:25:55 Info Drive has IDE-ATAPI physical interface
2010-04-22 16:25:55 Info New Drive selected : 5:0:0 - LITE-ON DVDRW LH-18A1P GL0B [D] (Ide)
2010-04-22 16:24:52 Info Current Drive selected : 5:0:0 - LITE-ON DVDRW LH-18A1P GL0B [D] (Ide)
2010-04-22 16:24:52 Info Using Advanced SPTI interface
2010-04-22 16:24:52 Info System default language : English (Canada)
2010-04-22 16:24:52 Info User default language : English (Canada)
2010-04-22 16:24:52 Info DLL Version : 4.0.7.466
2010-04-22 16:24:52 Info DLL : C:\Program Files\DVDFab 7\vso_hwe.dll
2010-04-22 16:24:52 Info Version : 7, 0, 4, 0
2010-04-22 16:24:52 Info ExeName : C:\Program Files\DVDFab 7\DVDFab.exe
2010-04-22 16:24:52 Info OS : Microsoft Windows XP Home Edition (Build 2600: Service Pack 3)
2010-04-22 16:24:52 ---- ******************** Log session start 22-Apr 16:24:52.859 PID 1508********************
I 20:22:38 ImgBurn Version 2.5.1.0 started!
I 20:22:38 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 20:22:38 Total Physical Memory: 2,030,956 KB - Available: 1,273,332 KB
I 20:22:38 Initialising SPTI...
I 20:22:38 Searching for SCSI / ATAPI devices...
I 20:22:38 -> Drive 1 - Info: LITE-ON DVDRW LH-18A1P GL0B (D(ATA)
I 20:22:38 Found 1 DVD±RW/RAM!
I 20:22:38 Operation Started!
I 20:22:38 Building Image Tree...
I 20:22:39 Checking Directory Depth...
I 20:22:39 Calculating Totals...
I 20:22:39 Preparing Image...
I 20:22:59 Using Layer Break LBA: 1748864 -> 1860624 (VTS_01, PGC: 1, Chapter: 18, Cell: 22, Vob/Cell ID: 2/1, Time: 01:15:06, SPLIP: Yes -> No)
I 20:22:59 Checking Path Length...
I 20:22:59 Contents: 11 Files, 2 Folders
I 20:22:59 Content Type: DVD Video
I 20:22:59 Data Type: MODE1/2048
I 20:22:59 File System(s): ISO9660, UDF (1.02)
I 20:22:59 Volume Label: AVATAR
I 20:22:59 IFO/BUP 32K Padding: Enabled
I 20:22:59 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 20:22:59 TV System: NTSC
I 20:22:59 Size: 7,391,602,688 bytes
I 20:22:59 Sectors: 3,609,181
I 20:22:59 Image Size: 7,621,115,904 bytes
I 20:22:59 Image Sectors: 3,721,248
I 20:22:59 Operation Successfully Completed! - Duration: 00:00:20
I 20:22:59 Operation Started!
I 20:22:59 Source File: -==/\/[BUILD IMAGE]\/\==-
I 20:22:59 Source File Sectors: 3,721,248 (MODE1/2048)
I 20:22:59 Source File Size: 7,621,115,904 bytes
I 20:22:59 Source File Volume Identifier: AVATAR
I 20:22:59 Source File Application Identifier: IMGBURN V2.5.1.0 - THE ULTIMATE IMAGE BURNER!
I 20:22:59 Source File Implementation Identifier: ImgBurn
I 20:22:59 Source File File System(s): ISO9660, UDF (1.02)
I 20:22:59 Destination Device: [5:0:0] LITE-ON DVDRW LH-18A1P GL0B (D(ATA)
I 20:22:59 Destination Media Type: DVD+R DL (Disc ID: RITEK-S04-66) (Speeds: 2.4x, 4x, 6x, 8x)
I 20:22:59 Destination Media Sectors: 4,173,824
I 20:22:59 Write Mode: DVD
I 20:22:59 Write Type: DAO
I 20:22:59 Write Speed: 4x
I 20:22:59 Link Size: Auto
I 20:22:59 Lock Volume: Yes
I 20:22:59 Test Mode: No
I 20:22:59 OPC: No
I 20:22:59 BURN-Proof: Enabled
W 20:23:04 DeviceIoControl(FSCTL_LOCK_VOLUME) Failed! - Reason: Access is denied.
W 20:23:04 DeviceIoControl(FSCTL_DISMOUNT_VOLUME) Failed! - Reason: Access is denied.
I 20:23:04 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 20:23:04 Book Type Setting: DVD-ROM
I 20:23:04 Advanced Settings - Force HT: No, Online HT: No, OverSpeed: No, SmartBurn: Yes
I 20:23:04 Optimal L0 Data Zone Capacity: 1,860,624
I 20:23:04 Optimal L0 Data Zone Method: IFO Cell Boundary
I 20:24:06 Set L0 Data Zone Capacity Succeeded!
I 20:24:06 Filling Buffer... (40 MB)
I 20:24:07 Writing LeadIn...
I 20:24:09 Writing Session 1 of 1... (1 Track, LBA: 0 - 3721247)
I 20:24:09 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3721247)
I 20:24:09 Writing Layer 0... (LBA: 0 - 1860623)
I 20:35:39 Writing Layer 1... (LBA: 1860624 - 3721247)
I 20:47:11 Synchronising Cache...
I 20:47:14 Closing Track...
I 20:47:23 Finalising Disc...
I 20:48:06 Exporting Graph Data...
I 20:48:06 Graph Data File: C:\Documents and Settings\Chris Hoffman\Application Data\ImgBurn\Graph Data Files\LITE-ON_DVDRW_LH-18A1P_GL0B_APRIL-23-2010_8-22_PM_RITEK-S04-66_4x.ibg
I 20:48:06 Export Successfully Completed!
I 20:48:06 Operation Successfully Completed! - Duration: 00:25:03
I 20:48:06 Average Write Rate: 5,389 KB/s (3.9x) - Maximum Write Rate: 5,645 KB/s (4.1x)
I 20:48:06 Close Request Acknowledged
I 20:48:06 Closing Down...
I 20:48:06 Shutting down SPTI...
I 20:48:06 ImgBurn closed!
Gotta go soon work in a while will check back tomorrow. Tks for all the help guys, its appreciated.
Cheers!Chris
@chris
[ATTACH]877[/ATTACH]
OK, VSO inspector shows it as DVD +R DL but I changed in imgburn? How do I change via inspector? Or where do I go?
Tks.Chris
I'm guessing chris's LITE-ON DVDRW LH-18A1P successfully bitset the disc to DVD-ROM. Not sure why it won't play though unless it's the media (RITEK-S04-66) and/or the old firmware on it.
Not to get to technical but GL0B is very old firmware. GL0J is the newest
@maineman thank you for the VSO Inspector link. I had version 1.2.7 here"You've got a hole in your soul if you don't dig the Blues"
Keith Richards ~ "If You Want The Last Laugh........Join The Rolling Stones"
Click to join forum.dvdfab.com
