Avatar on DVD.
    Avatar on DVD.
    Perfectly happy with DVD Fab, and in general have NO problems at all with it (although saying that will probably jinx it), PLEASE keep up the great work.
    I just have a general question, couldn't see an answer, sorry IF there is.
    Like many I am eagerly waiting to buy Avatar soon, on DVD I don't have Blu-ray.
    I noticed a post here now where ''fengtao'' says about the new protection on Avatar for Blu-ray being overcome already, I take it that the latest version of DVD Fab also copies the DVD version of Avatar with no problems?
    THANK YOU...................
    davidh
    Yes it will copy I did mine R1 no problem version 7040.
      Thanks, it is region 4 I am worried about though.
      Hope that still applies?
        davidh
        I'm not sure about region 4 but I would have to say I think Fab will be able to do it right now I'll keep reading posts and if I see it I'll post back or maybe someone in region 4 will post success on it.
        CBR929
          Thanks again.
          When I posted the question GregiBoy was on line, he is just down the road, and even fengtao himself was on line, hopefully someone will know for sure?
            As posted on another thread both V7.0.4.0 and V 7.0.4.5B will copy Avatar R4 with no problem.
            As will Passkey used with several other programs.
              Thanks Gruñón I was unsure.
                Thank you.
                I couldn't see the other thread, sorry.
                  Originally posted by davidh View Post
                  Thank you.
                  I made the post and I could not find it post a link .....
                    Okay, well no wonder I could not find it.
                    Feel free to lock this thread now IF you want to.
                      davidh
                      CBR929
                      Avatar DVD Reqion 4 will be released on 29th April 2010. It's only 4 days to go then we'll know
                        What is it you did not understand about post #6.
                        There is no problem with Avatar R4.
