DVDFab and Other software
    I use DVDFab to convert my DVDs into VOB files, which I then convert into MP4 using other software. I like to use other software for the conversion to MP4 because the video quality appears to be much better when I play the movies on my TV. Since upgrading to the latest version of DVDFab, I have had a problem with converting the VOB files into MP4 using other software. Other software keeps giving me the error code "Resampling with input channels greater than 2 unsupported". Does anyone know if there is a setting in DVDFab that I can change to correct this?
    I really appreciate the help.
    Quick fix is to roll back to DVDFab v.6. Fab 7 have new platform and new engine, so it would take some time before everything settles. So, I would suggest to use v.6 for a while. BTW, v.6 and v.7 can coexist on your machine without interfering.
    sigpic
      go to the other softwares forum for help
      Thread Closed
