I have been trying for 3 days to copy "the Blind Side" dvd, each time it will copy to my computer, but when i go to put my blank dvd in my burner, it says that i have a single layer disc and i need a double layer one. it also said that i need to change the setting under the "write" tab to have Dvd 5 set at 2600, so that the program will compress the movie and make it fit on the disc. I had previously Dvd fab 6, just uninstalled it and downloaded the new beta version thinking it would work, same problem. I have windows vista. if anyone knows how to fix this problem, please let me know. thanks
Single Layer disc error
dmaiello
You can try to go back into settings and change your size in DVD-5 to 4472, also when you open Fab an it analyzes the disc make sure on the bottom it is set to DVD-5 also.
If you are using the Free version you will not be able to compress the movie.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
no the trial has not run out, i have unitl may 25th, i did change it to 2600, but like i said, i downloaded the new beta version which is 7, and i changed the setting for 5, but there are setting for 6 that i cant change, it saves them, and when the main screen comes up that analyzes the discs it is one dvd 5, so everything is correct, it copy the movie to the computer, it just wont burn it to the dvd...i dunno, i have never had this many problems getting a movie to burn, and like i said i have done tons i have used this program for years..
Originally posted by dmaiello View PostI have been trying for 3 days to copy "the Blind Side" dvd, each time it will copy to my computer, but when i go to put my blank dvd in my burner, it says that i have a single layer disc and i need a double layer one. it also said that i need to change the setting under the "write" tab to have Dvd 5 set at 2600, so that the program will compress the movie and make it fit on the disc. I had previously Dvd fab 6, just uninstalled it and downloaded the new beta version thinking it would work, same problem. I have windows vista. if anyone knows how to fix this problem, please let me know. thanksOriginally posted by dmaiello View Postno the trial has not run out, i have unitl may 25th, i did change it to 2600, but like i said, i downloaded the new beta version which is 7, and i changed the setting for 5, but there are setting for 6 that i cant change, it saves them, and when the main screen comes up that analyzes the discs it is one dvd 5, so everything is correct, it copy the movie to the computer, it just wont burn it to the dvd...i dunno, i have never had this many problems getting a movie to burn, and like i said i have done tons i have used this program for years..
you have used this program for years but still have the trial till May 25 and you have had it for the past 3 days. That does not add up to me and I do believe your trial is over and the free version does not compress or burn to DVD
oh ok, I guess people are not entitled to buy new computers..hum shame on me..well thats what i did, and then I had lost everything on this 1 and had to re-format it, which then let me install the program again. Im sorry that I tried to ask for support on this issue.. I will find another program to use in the future.
Originally posted by dmaiello View Postthen I had lost everything on this 1 and had to re-format it,
I have to say Fab is well worth the money that I spent on it considering that it works and support is always here to help.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by dmaiello View Postoh ok, I guess people are not entitled to buy new computers..hum shame on me..well thats what i did, and then I had lost everything on this 1 and had to re-format it, which then let me install the program again. Im sorry that I tried to ask for support on this issue.. I will find another program to use in the future."Beer is living proof that God loves us and wants us to be happy."- Benjamin Franklin 1706-1790
Originally posted by maineman View PostHow large are the files ripped to your hdd?
Does the flick play back ok from the hdd with a software player such as VLC?Originally posted by dmaiello View Postoh ok, I guess people are not entitled to buy new computers..hum shame on me..well thats what i did, and then I had lost everything on this 1 and had to re-format it, which then let me install the program again. Im sorry that I tried to ask for support on this issue.. I will find another program to use in the future.
???If it ain't broke, don't fix it!
Originally posted by GregiBoy View PostMaineman, I think this whole thread is a Red Herring as he "has used it for years" and it is the free version.
Fab would begin a new trial.
I'm still curious as to the answers to my original questions...we need details to troubleshootIf it ain't broke, don't fix it!
