Eliminating SUbtitles
    Sorry to ask such a noob question but I don't see how I can always force DVDFAB to never include Subtitles unless they are mandatory because of a foreign language segment in a movie.
    forced subtitles can not be removed but regular ones can when you untick them before you start the copy process
      bushy
      Open Fab click the green check on top > Streams > Sub picture > click do not select any sub picture track on top also do not select any track on the bottom then click OK.
      Hope this helps
      CBR929
        Wow, thanks for the very quick replies. Is there a way to setup a profile for DVD to Mobile to deal with the elimination of Subtitles?
          bushy
          Hope this helps
          CBR929
          Do what CBR929 mentioned in the quote and then test it out
            I will do what CBR929 suggested, I assumed his suggestion requires re-application for each use of DVDFAB. I did not understand that this would be a persistent solution.
              I don't think you mean "Forced Subtitles" here but mean subtitles that are burnt into the video.
              Forced subtitles are always part of a subpicture stream, and to obtain them you need to select the correct stream and then forced subtitles only.
              Yes???
                If you do this in the settings page as suggested, it is then a persistent solution.
                  Perfect, thanks everyone for the help!!!!!!!
                    bushy
                    Your welcome glad I could help
