Blu_ray ???
    Blu_ray ???
    hi I have a samsung tsh662a dvdrw drive. Can I use the blu-ray on the dvdfab 7 to copy blu ray dvd's or do I have to buy a blu-ray dvdrw drive? thank you
    jss2
    You would have to buy a Blu-Ray drive if you want to backup Blu-Ray just make sure the drive can read and write disc's. You would also have to buy the Blu-Ray to Blu-Ray module from Fab.
    Hope this helps
    CBR929
      does thanks
