HD Decrypter dumb question
    I'm evaluating DVDFab and I'm confused.
    Whenever I try to rip a DVD from the DVD itself to the hard disk (same size - no compression), it tells me I'm actually using DVD to DVD.
    How do I do this with 'just HD decrypter'?
    (Using the new download 7.0.4.0 from the HD decrypter page of the website.)
    When the trial runs out, it will just turn to HD Decrypter which will behave exactly the same way but with no compression options and updates for new titles 60-90 days behind the paid version.
      Thank you!
