MKV to BluRay
    MKV to BluRay
    Will the program convert MKV to a file that BluRay will read? If not, what program do you recommend to convert the MKV before burning?
    I have an LG external BluRay Burner/Player and a Samsung BluRay Player. It is the Samsung that I want to play it on.
    Thanks.
    Some of the newest BR Pl ayes are capable playing MKV. You may want to check if your player is one of them. DVDFab can not re-mux MKVs to Blu-ray, but you can use tsMuxerGUI (google it, it's free) to re-mux MKV into Blu-ray.
    sigpic
      @8ternity
      last 3 posts deleted as posting a program that does same thing DVDFab does is not allowed
