File to mobile
    File to mobile
    Hiya Fellas . . .
    I purchased DVDFab years ago back when it was a lifelong subscription (love this product).
    I cannot seem to find documentation stating if I should also have access to "FILE TO MOBILE" or if it is an upgrade I have to purchase.
    Does anybody know?
    Thanks guys.
    If you purchased File to Mobile option, you should have it. You can easy check on what license do you have by going to info section (in right top corner of main window blue circle with question mark in it) -> About. In a pop-up window you will see all your licenses for all options. If you don't have for File to Mobile and you wish to purchase it, click on "Secure order Now!" link in registration section of this window, it will prompt you to the purchase options site.
    sigpic
      You have to buy file to mobile as that is a new option that was not included with the old lifetime gold and platinum versions
