Auto play
    Auto play
    I just replaced my hd and reinstalled dvdfab 7. How do Iget dvdfab to show up in quick launch option list? Thanks Dan
    EasyXjer
    Right click DVD Fab from desktop click add to quick launch
    CBR929
      Thanks for the instructions.
        EasyXjer
        Your welcome
        CBR929
          Ok terminology error encountered. I need to get dvd fab into the auto play list so when I insert dvd it shows up in auto play window. Thanks.
            Probably the simplest approach here is to enable Auto Play handler.
            Common Settings > General > tick on
            Add Auto play handler (Optionally, start DVDFab when DVD inserted
            I think this will do it for you.
