How can I play a ripped DVD?
    I have ripped a DVD using DVD to DVD and the folders Audio_TS and Video_TS are in a folder named DVD_Volume. What program do I use to play back the ripped DVD in a PC and Mac?
    Thanks
    Andy
    AndyHutch
    iMac 27 running Parallels w/Win7
    VLC...(Free)
    www.videolan.org
      andyhutch1947
      You can use VLC you will find it here http://www.videolan.org/vlc/
      I use it for windows not sure about mac
      hope this helps
      CBR929
      didn't see you GregiBoy
        Or Media Player Classic even better
        MPC-HC, the free, open source media player for Windows
        Sorry to burst your bubble, GregiBoy
        sigpic
          ...or MediaPortal
          MediaPortal transforms your PC into a complete media solution. It runs on basic hardware, connects directly to your TV and displays your TV Series, Movies, Photos and Music in a much more dynamic way. All in the comfort of your living room, on your big sc
            There are versions fo MAC OS X and Linux.
            andyhutch1947
            hope this helps
            CBR929
              Sorry to burst yours IP but the original poster asked about Win & MAC and as far as I understand, MPC is Win only.
                Thanks GregiBoy I was not sure, I have only used windows
