Bluray to mobile (.mkv remux) cropping issues..
    I just started using DVDfab for ripping Bluray. When I chose to go from Bluray to .MKV (remux) I chose to auto crop and it shows in the picture the black bars getting deleted. When I get the finished file the black bars are still there.
    Any help would be appreciated.
    thanks
    Since the idea of remux is pretty much passthrough (just a container change), autocrop might not be a good idea. Please try to use custom crop (manually), it might work.
    thanks
    sigpic
      Remux option cannot crop because the video stream is not modified. Your crop selections are ignored. Any of the other profiles will work.
        That makes sense.. Thanks guys.
