Looking for advice on what to do with series.
Currently (because I'm still determining what I'm actually going to do), here is my current situation.
I make everything into an ISO and put it on my NAS (this includes series). I keep PS3MS loaded on one computer, so when ever I want to watch a series (or movie), I can turn on my PS3 and go get it. For me, not that big of an issue, I can open the ISO file and see all the different series as title1/title2 and I just follow them in order.
What I'm thinking I'd like to do (for the other folk whom I live with), is maybe make each episode a separate file that I can rename (Episode # maybe?). Then I got thinking, what if I can go a step further, and make a super simply menu for them. Not sure if this is possible to stream.. but make a little menu that would list all them and you can select them, or have an option to Play all.
So 2 part question:
What is my best method for doing episodes (All DVD right now, maybe blu-ray later.. but for now DVD only). I refuse to degrade my quality - so passthroughs for me.
Also to add.. If I need too, I'd like to be able to load these files back into DVD Fab and burn to a DVD (that would play on a standalone dvd player). Would make life much easier than finding the disc again (don't get me started about keeping a catalog of where all your discs are.. ..).
Is it possible to make a menu? If so can someone direct me on how/where/what is needed? (Even if you give me google terms that work.. because "how to make a menu for a DVD to play on a ps3" doesn't)
So 2 part question:
