What software
    What software
    I would like to rip both DVD and Blu-ray movies both to disk and iphone. Can someone please tell me which software otions i need to purchase to make this happen?
    tech2spec
    Hello and welcome
    You would need to purchase DVD to DVD, DVD to Mobile, Blu-Ray to BLU-Ray, and also Blu-Ray to Mobile.
    Hope this helps
    CBR929
      Thanks for your reply. Looking at the total cost for all the mentioned modules, £143 GBP, it seems quite expensive compared to other software titles offering the same options.
        Would the Blue-ray to Blue-ray option also do DVD's
          That would be your choice but, for me I have used other software claiming to do what I wanted and have since moved away from them because they didn't work and their support was horrible.
          No just BluRays
          CBR929
            Does the "Blue-Ray to Blue-Ray" also do "DVD to DVD"?
              Thanks, you have been most helpful
                No because the file structure is different and also the codes
                CBR929
                  tech2spec
                  Your welcome I am glad I could help
                  Since I found DVD Fab I have never looked back
                  CBR929
                    tech2spec
                    I should have also mentioned if this helps, that you can do a Free 30 day trial of Fab to to test the functions and make your decision that way
                    Brain was not working (must have been the first cup of coffee)
                    CBR929
