Ripping help
    Other Ripping help
    I tryed DVDFab HD Decripter but you can't just pick one Chapter from the DVD to Rip.
    And I did not want to pay for any Ripping programs.
    I tryed DVD Decripter and found a web site that talks about difeant settings to make it work on Hard to Decript DVDs.
    So I made all the settings and still wont Decript my DVDs.
    I tryed REMOVED and no good did not work.
    The only program that works for me is REMOVED
    But my Audio and Video are always off.
    But it does have a A/V check Box so I check it.
    And the numbers go like this 0.000
    It says Negitive Numbers Delay Audio and Positive Numbers Delay Video.
    Now my Audio is always ahead of the Video say Five Seconds.
    So would I want to Delay my Audio by 5 Seconds??
    And would I type -5.000????
    Last edited by GregiBoy; 05-16-2010, 11:11 PM. Reason: Software References removed.
    This is a DVDFAB help forum if you need help with this software you will find it here.
    If you want help and to discuss other software because you do not want to buy DVDFAB I suggest you go to the other software forums.
    Thread Closed.
