Single layer error
    Other Single layer error
    I've had DVD fab for a while and just recently have been getting error messages that I have sinle layer DVD and I need dual layer. I've been burnining to these dvd's for a while and I'm not sure why I'm getting that error. Any thoughts?
    Are your DVDs single or dual?
    sigpic
      Make sure that you have the size set to DVD5 in the pulldown at the bottom of the Fab pane.
        Single Layer
        For some reason the forum wouldn't let me post a reply on the other thread so I'm having to post a new one. I have single layer DVD's and I get an error saying that I need dual layer. I've tried changing the quality to DVD5 but I get an error that state my "DVD to DVD option is expired". How can I renew so that I do get DVD5 quality option?
          Something tells me that you were using trial version that expired. That's why Fab wouldn't compress your content anymore. Cure for this situation is very simple - go and buy the program if you find it useful and helpful.
          sigpic
            No... I've had the full version for years.... I don't think I need to buy it again.
            I have my registration key... Thoughts?
              Yes do what is listed in link below to fix your problem
                No, you don't need to buy it again, you just need re-register your key. If it showed as expired, somewhere with upgrade you have lost your registration, which is not big deal and easy to fix. And just for verification, please click little blue circle in top right corner of DVDFab window ->About -> Welcome window will open. Do you see your license information there or is it in trial version. Don't post it here, just tell me if you see it or not
                AGJ, you are faster, as usual... Oh well, I'm getting old and will go ask maineman for membership in his "old farts" club
                sigpic
                  Its possible that his subscription ran out as well and its not letting him compress anymore, but he didn't notice it and just kept on steamin'.
                  SPECS
                    You will have to do a lot of sweet talking as it is a very exclusive membership...
                      GregiBoy, as you may noticed I'm very good and sweet talker And I can do it on more than one language Would you endorse my membership
                      sigpic
                        Thanks...l re-registered my key and it all works as advertised. Thanks again!!
                          Salaam aliakum habibi, kefhaq? = Arabic Greetings my friend, how are you?
                          Selamat malam, kabar baik? = Bahasa Indonesia/Malayu = Good evening, are you well?
                          Yeah. I do to but not european ones, Asian/Middle Eastern is my bag......
                          Most important phrase I have ever learnt in Indonesian
                          Satu Bir Dingin Lagi tidak es, Tremakasi = One more cold beer again without ice, please.
                            Good to know your up and working like usual again
