Burn BD folders
    Burn BD folders
    Hello,
    Does DVDFab have the ability to burn blu-ray from blu-ray movie folders?
    Thank you
    Yes it does if you purchase the BR/BR module.
      that's the option I have BR/BR. I don't see a way to create BR from folders.
      Thanks
        What exactly folders are you talking about (do they have a name, how many of them, is that a rip made with DVDFab????) and where did they came from??
        sigpic
          It's BD movie folders.It has subfolders BDMV\STREAM, \CERTIFICATE, etc., and was created from ANYDvd.
            Why are you here then??? Are you using both programs??? Did you asked on their forum?
            Anyway, only here you can really get help, that's the reality.
            OK, there are two ways:
            (1) Open your movie folder with DVDFab as source, and assign you BD drive as destination. Click OK
            (2) Open ImgBurn ->"Write files/folders to disc" -> open source, destination, click OK
            If you don't have ImgBurn on your machine, it's not too late to get it and pare it up with DVDFab. You can find instructions here:
            sigpic
              OK great. Thanks for the DVDFab/ImgBurn info. I'll try it.
              Sometimes DVDFab doesn't work so I have to use ANYDvd write to folders. I tried BDClown, TSMuxer and could'nt figure it out so I bought DVDFab.
              Thanks.
