Dvd source issue
    Dvd source issue
    Im having an issue. I have an external hard drive that i have put all my movies on. When i go in to dvd fab to burn a movie and pull up the drive in the source box for some reason it will only show me the last movie i burned. all the other files are gone. to fix it i half to keep changing the name of the main dir folder, after every movie i burn.
    I save to external and internal and do not have that problem when I bring the files up to burn them at different time.
    Are you sure that you are selecting the "Temp-FullDisc-name of movie" or "Temp-MainMovie-name of movie" to get what you need. Also do you have do not delete temp files when done selected in the common settings of DVDFab as that could be problem as well
