Hi guys
I just found out about these products and they look great. Now I downloaded the DVD decryptor HD and it seems that it downloaded the whole suite. I read the description on the website and it says that it breaks the copy protection and copies the full movie to the computer. When I run the program no matter what option I choose it says "you are trying DVD to DVD" then the 30 day free trial starts. My question is what do you have to do to just use the free program. Then I started to wonder if it was only a decryptor. Such as opening the DVD with it and just leaving it running in the back ground while you launch another ripping program. But it did state on the site that it copied as well, so I'm kinda confused now. I was also wondering what the difference is between decryptor HD and freedvd. In advance thank you all for your time.
