Incorrect length info on sub-files of some movies
    As the free trial period runs out I am getting used to using the Decryptor to download DVD files to be burned by WindowsDVDMaker. I kinda like their menu maker.
    It looks like part of the process is to break the whole content down into 4 or 5 files of 20 to 30 minutes long.
    Some movies -Aeon Flux for one- have a sub-file that is 20 or so min, but, has a label of 20 hours plus. ie: instead of 00:23:45 it would read 23:45:10.
    DVDFab does not read this info I guess, but, the DVD Maker does and says, "can't do it!"
    Is this length info coming directly from the DVD or is it added by the DVDFab? If the latter maybe there is a 'fix'. If the former, can anyone suggest a free DVD burner that would ignore this sub-file info?
    Thanks for all the time and effort you folks put into this.
    Give ImgBurn a try as it has no problem burning the files created by DVDFab but ImgBurn does not have a menu maker as it only a burn engine but is the best burn engine also ImgBurn is free
