Audio and Video tS file
    Other Audio and Video tS file
    When I put the copy of Blind Side that I copies in DVD FAb in my computer the movie didn't start. I went to my DVD drive and it shows 2 files Audio_ts and Video_ts.
    Should my backup of Blind Side start when I insert it into the computer? Also when I try this disk in my dvd stand alone player it does not work.
    How do I get this backed up DVD to work in my stand alone and also my Computer. I used the trial version.
    Hi Lenora and welcome
    Could you please post you logs The default location is:
    C:\Documents and Settings\User Name\My Documents\DVDFab\Log.
    Please just copy and paste the burn log(s) and post right here.
    Thank you
    CBR929
      If autoplay is active the DVD should start to play but if Autoplay is disabled then it not start when inserted in DVD drive. To play go to computer right click the DVD drive with the DVD in it and select Play. If it plays then good if not then something happened during the rip and burn so we really need those log files that CBR929 asked you for
