DVDFab HD Decrypter
    Other DVDFab HD Decrypter
    How do I use this. I downloaded as it says and at the bottom it says it will never expire. When I click DVDFab to start it goes into the DVD to DVD option. And says you will try this for 30 days. I chose Full Disc, only changed from DVD5 to DVD9.
    how can i use just DVDFab HD Drcrypter? no trial?
    There is no way to use DVDFab HD Decryptor with out using the trial first. The trial is for 30 days and has no restrictions like the free version has. After 30 days it will revert to the free version
      oh so i'm good, it will still let me rip the full disc to my computer without needing to buy a key.
      thanks
        Yes but you may want to read this link below as well
        IMPORTANT ANNOUNCEMENT REGARDING DVDFab HD Decrypter
