I've been using DVDFab since May 08, and a verision that I like is DVDFab 7.0.4.0. The problem is I lost part of the program, thanks AVG, I would really like another copy. Can any one help?
DVDfab 7.0.4.0
First, update your AVG again because they've apparently fixed that bug. Then just version and re-install. Older versions don't support the latest copy protection schemes.
You can also restore any files AVG removes by opening AVG's virus vault, selecting the file, and clicking Restore. (But of course you need to update AVG first, so it doesn't keep quarantining the same file over and over again.)
