Help!!!
    Help!!!
    how can i split a movie like avatar that won't fit on one dvd. without using a double layer dvd..
    If you are using the free version it will not split a movie.
    If a registered version click on the attachment below.
      can't open the tutorial
        Yes you can.... open your version of Fab and click on the [?] to open the tutorial.
        The attachment was simply to show you where to look for it.
          Click on the ? mark icon upper right of opening screen or view it online @ DVDFab.com
          //Edit
          Hey G.
          I'm having trouble dealing with the fact that I'm continually beaten by another old fart even older than myself.
          I guess I should get used to it...
            //Edit
            Hey G.
            I got lucky.
