Original Sin DVD shows is 2MB on DVDFab 7.0.9.2
    I just updated my DVDFab to 7.0.9.2 and DVDFab Passkey to 7.0.3.6 and Passkey shows that movie is 3649MBytes per layer, which looks fine, but when I open DVDFab it reads it as a 2MB movie. I had the same issue with an older DVDFab version and found out about an update so went ahead and updated but still the same reading of 2MB.
    Any suggestions anyone? I have been using DVDFab for quite sometime and this is the first time I have encounter an issue that I could not find no help on the forum about it. I run it on Win7 Ultimate 64bit.
    Have you tried disabling PathPlayer (or enabling if already disabled)?
    I don't have this flick so I'm not much help here.
    If this doesn't do it, please run through the list in my thread
    Tips on Troubleshooting Analyzing/Ripping dvds
    (link in my sig below)
    Also be certain to clean the disc as described in #3...regardless.
    You're not running Fab and Passkey together are you?...they're likley to conflict with one another.
      Conflict with one another?
      OMG... I found the problem, I did not know that Passkey was not supposed to be used along with Fab, what is the point of having it then???
      I'm sorry, it is just that I come from a competitor that uses its decrypter separate from its burning software so I thought this was the same, I guess not now.
      Thanks for your help. Shutting down Passkey solved the issue!
      Carlos.
        You're welcome Carlos, glad to hear you're up and running again.
        As a general rule, it's not a good idea to run more than 1 decrypter simultaneously as they will likely conflict, just as you have experienced.
        You could use Passkey with Fab if you were to untick all the Remove Protections, but then what would be the point?
        Having said this, if you run out of options, I'd give it a shot.
        I've had occasion to run 2 decrypters simultaneously in the past, and with some success.
        Passkey is essentially a windows driver...an on-the-fly decrypter,
        whereas Fab is a complete, will pretty much do it all, software.
        Passkey is not a standalone app, but can be used with many other apps such as Img, shrink, nero recode, etc.
        For a detailed list see:
